Message 1 of 6
BT Router
Hi, quick question.
What does the broadband port do/mean on my router?
Do I need to have anything plugged into it?
Thank you,
Tom 🙂
5 REPLIES 5
Message 2 of 6
Re: BT Router
Have a look at this link and follow the guide for the type of BT hub that you have.
How to set up BT Broadband | BT Help
Message 3 of 6
Re: BT Router
Hi, yes I’ve seen this.
I’m more interested if I need to use the broadband slot and what it is?
Message 4 of 6
Re: BT Router
@Tommy69
It depends.
If you have Full Fibre then the answer is NO otherwise it's where your internet input (from the phone line) plugs into.
Message 5 of 6
Re: BT Router
@Tommy69 If you actually read the guides linked you would understand how the ports are used.
Message 6 of 6
Re: BT Router
The SH2 ( if that’s the router in question) will work with FTTC/ADSL as well as FTTP , so as stated , if you have BT FTTP , its an unused socket , if you have FTTC or ADSL then it’s connected to the copper pair phone line
