Message 1 of 4
BT Smart Hub Flashing Purple yet working OK
My Smart Hub 2 is flashing purple continuously having apparently restarted about 7 hours ago. However the internet is working fine and at full speed. I'm reluctant to reboot it in case there is a problem and I lose internet.
I have full fibre gigabit, and speed is normal.
Any ideas?
3 REPLIES 3
Message 2 of 4
Re: BT Smart Hub Flashing Purple yet working OK
did your firmware update?  if so maybe it did not fully update and needs a restart
Message 3 of 4
Last firmware update shows 6 October to level v0.37.00.07084-BT. Think it's rebooted before now for that.
Message 4 of 4
OK - held my breath and restarted it. Now gone back to blue. Phew!
