Message 1 of 19
BT broadband blue light but no internet
The BT hub has a blue light but no internet on any device. The small hybrid box the same does not provide WiFi. It has been 2 days already . This is so frustrating any tips? I hope my account is credited for the days of loss of service
18 REPLIES 18
Message 2 of 19
Re: BT broadband blue light but no internet
Have you actually reported the fault to Customer Services?
Message 3 of 19
@zetayer Welcome to the community and thanks for posting, if the Hub has a blue light it indicates that there are no network issues. Is it only wireless devices you're experiencing issues with? Have you tried connecting a device using an ethernet cable to see if you can get a connection?
The Hybrid connect only kicks in when the network goes down, as your Hub still has a blue light which is likely stopping the hybrid box from starting up. Turning off the Home Hub should allow the Hybrid box to start working.
Neil
Message 4 of 19
Even with ethernet cable the device does not connect. For a few minutes internet connected on a couple of devices and it stopped working again. If you switch off the main hub the hybrid hub does not give WiFi either
Message 5 of 19
@zetayer have you tried a factory reset of the Hub?
Neil
Message 6 of 19
Yep that's when a couple of devices connected but quickly it came back to the same issue as before
Message 7 of 19
@zetayer that's a strange one, have you tried manually changing the wifi channels on the hub?
Neil
Message 8 of 19
How do I do that? Because the 192 code for the modem does not work as there is no WiFi signal
Message 9 of 19
@zetayer If you factory reset will it allow you to connect again?
Neil
Message 10 of 19
Just factory reset it again and it still does not connect, nor allows me to log into the 192.and it shows blue light again 🫣
