Message 1 of 2
Broadband Connection dropping
BT broadband connection keeps dropping. The lights change to flashing orange and purple a few times a day for the past several months now. Very frustrating as I work from home too.
The area connection seems to be fine and I have tried restarting the Hub too which hasn’t helped.
Any help would be appreciated!
1 REPLY 1
Message 2 of 2
Re: Broadband Connection dropping
provided you are not on digital voice can you check your phone line for noise by dialling 17070 option 2  should be totally silent
have you tried using the test socket with a filter to see if that helps connection stability
