Message 1 of 7
Broadband connected without Internet
  • I recently changed to full fibre and it didn't drop out before. Does anyone have any advice to do to help
6 REPLIES 6
Message 2 of 7
Re: Broadband connected without Internet
are lights on ONT green like this
what colour is hub light?
Message 3 of 7
All 3 lights are green, is the Lan supposed to flash
Message 4 of 7
yes  that would suggest hub connected and internet working  what about hub lights
Message 5 of 7
Hub lights blue
Message 6 of 7
green lights on ONT and blue on hub suggest your internet is working.  are you using an ethernet cable to connect your device as wireless maybe causing you a problem
Message 7 of 7
I have noticed its better since I disconnected my phone from broadband and reconnected with password so thanks alot
