Message 11 of 14
Re: Broadband died in Xmas Eve
Still doesn’t explain why the phone works and the broadband is dead
Message 12 of 14
@Ebabdude
Please reply to question on this post https://community.bt.com/t5/BT-Fibre-broadband/Broadband-died-in-Xmas-Eve/m-p/2336850#M351271
Forum members need to know what broadband equipment you have connected to your phone line, if you want more help.
Message 13 of 14
Probably a faulty Port in the DSLAM.
Message 14 of 14
@Ebabdude I had an intermittent fault with my FTTC a good few years ago. Phoneline worked fine but every few days my FTTC would disconnect for a good 5 mins or so in the evenings.
I was using the BT Home Hub 4 at the time with an Openreach modem.
Toke them over a week to find and fix the fault after I reported it and two more phone calls to BT.
Seems at times phoneline can work mostly ok but broadband can have a fault.
Glad isp companies now longer use the likes of the Openreach modem box for FTTC. For  every year or two the white modem box would be 9 times out of 10 the problem for the internet not working,
