Message 1 of 4
Cannot connect to office routers. Traceroute fails on DSL but works on 4G failover.
Hi,
I'm having issue connecting to BT IP addresses that I use for work. If I connect try with the DSL line connected traceroute fails, if I disconnect the DSL line and use 4G BT failover then it works correctly. Tethering to a mobile also works.
Martin
3 REPLIES 3
Message 2 of 4
Re: Cannot connect to office routers. Traceroute fails on DSL but works on 4G failover.
@martinbirch
Welcome to this user forum for BT Retail phone and broadband customers.
Are you a Business user?
Message 3 of 4
Hi
Yes, I'm a business user.
Regards
Martin
Message 4 of 4
this is residential so you need to post here
https://business.forums.bt.com/
