Message 1 of 3
Contact BT by E-Mail
Hi, how do i contact BT via E-Mail about a full fibre issue I'm having after upgrading to 900 MBPS. The only e-mail address I can find is now defunct
2 REPLIES 2
Message 2 of 3
Re: Contact BT by E-Mail
@niagh01
Short answer is, you can’t
See this link and follow the procedure:
https://www.bt.com/help/contact-bt/technical-support/broadband
Message 3 of 3
Hi Kimberlin, thanks for the information
