Message 11 of 17
Re: Cowboy Fibre Installation Fail
A Lead In Kit requires a 12mm Drill Bit.
Although on Plaster Boards Walls you can get away with using a 10mm Drill Bit.
Anonymous
Not applicable
Message 12 of 17
This is the standard of work I was expecting.
Message 13 of 17
This is actually good to see, I’ve never seen an install like this before.
EE900 | Nokia ONT | Ubiquiti ER-X | EETV Box Pro (IP Mode) | Unifi CK2 | 6x Unifi U6+ | 4x Unifi SAK Ultra
Message 14 of 17
The Install I’ve shown in that picture is awful.
If I’d done that when I was a CST I’d have been embarrassed and probably filled in the Complaint Form for the Customer myself.
For a start there is absolutely no need for the cleat to be there, looks ridiculous.
The Bend Radius on that Connector is a  borderline bend radius failure.
Finally the Inside Out Kit doesn’t need to be that far from the ONT, it should be situated pretty much next to it with a clearance of about 15mm.
Anonymous
Not applicable
Message 15 of 17
Here here, I couldn’t agree more. As a network engineer myself (ex Google/Facebook) I was merely being sarcastic in my earlier response. What should be happening is the engineer should be installing a small rack mount cabinet in my office and terminating that fibre into a Cisco cat 9K switch with 1G SFP uplink. A/C should also be included as part of the installation in order to provide sufficient cooling.
Message 16 of 17
It's same for me. They cut my old copper connection off, then found a blocked duct. That was on the 25june and not even got a date for when they will be fixing it. I have no Internet or phone line. They damaged the brick surface out side. It's taken a chunk of the brick surface off and left the porous internal material open to the rain. It's been a C.F from start to finish.
The communication between me as a customer and them as a provider has been abysmal. Only time I hear from them is when I chase them and they say "We have no update from Openreach"
I'm beyond frustrated now!
Message 17 of 17
If want to complain about an Openreach engineer’s workmanship you should refer to the following.
https://www.openreach.com/help-and-support/when-to-get-in-touch-with-openreach/complaints-policy
