Message 11 of 19
Re: DLM reset required
Here's the log from the hub 6 modem the BT director office sent us, it's still exactly (and fixed at) 20.00 Mbps no matter what ..
Message 12 of 19
You appear to be a business customer, if so no-one on this retail forum can help you.
You should seek help on the BTBusiness Forum.
Message 13 of 19
See message 9.
Message 14 of 19
Thanks @gg30340  I stand corrected but why anyone would buy an ISP supplied router is beyond me. Any third party one would be far superior.
Message 15 of 19
Fully agree!
Message 16 of 19
oh right, interesting ! 🙂
The business modem was VERY cheap, so we thought we'd try it is all.
Message 17 of 19
It looks like we're not going to get much help from BT on here 😞  .. so will get the required DLM reset done via a direct call. Will give them a few days here first, see what happens.
Message 18 of 19
You won't get a DLM reset with a call without an engineer visit and a positive fault cleared.
DLM has banded your line which can take several weeks to release. Changing hubs and causing disconnections is not going to help, just make it worse.
Message 19 of 19
A call was made today and they are coming straight out tomorrow to sort it (remove the cap).
