Message 21 of 22
Re: Ethernet ports
Ah, but a stronger signal does not necessarily mean faster.
Message 22 of 22
Re: Ethernet ports
If you connect a WiFi disc to the router, and that disc is too close to the router, your connection speed is likely to decrease.  Too much WiFi in too small an area is bad!
I only learn by making mistakes and owning up to them - boy do I learn a lot!
