Message 1 of 4
FTTP IPv6 Issue
Hello.
I upgraded from FTTC to FTTP a few months ago. My FTTC connection had IPv6 active, but it never had IPv6 when I switched over to FTTP.
My hub, which is the BT hub, has IPv6 enabled in the advanced settings, but it states that the IPv6 network status is disabled. The test-ipv6.com website also gives a 0/10 score stating that I do not have an IPv6 address.
Darran.
3 REPLIES 3
Message 2 of 4
Re: FTTP IPv6 Issue
Hi @DarranRowe, sorry you can't get an IPV6 connection.
I've sent you a Private Message so you can get in touch with the Mod team for help fixing this.
Cheers
John
Message 3 of 4
Re: FTTP IPv6 Issue
@DarranRowe Thanks for confirming this is now resolved. For the wider community, there was a configuration issue on the multi service edge router that was resolved by our network team.
Neil
Message 4 of 4
Re: FTTP IPv6 Issue
