Message 11 of 19
Re: FTTP PON light is flashing on my ONT modem, what is wrong?
Had a visit from an Openreach engineer today. Said the FTTP ID is wrong and he cannot fix it so the Openreach 'Tiger Team' is probably going to be brought in.
Message 12 of 19
According to BT there is something wrong with the installation of the FTTP junction box at my block of flats, I will have to wait until June 7th or later for it to be fixed.
Message 13 of 19
This sounds horribly familiar. We are the first occupants of an apartment in a new block of 10 flats which was fully wired by the developers. Same symptoms but I’ve been supplied with an EE mini hub FOC as a stop gap,  unsatisfactory but at least we have email & internet until the fibre issue is resolved. Last message was ‘wait until early next week & contact us again if PON still flashing’.
La vie est dur sans confiture.
Message 14 of 19
Now I have to wait for 54 metres of underground ducting work to be completed outside my flat because Openreach think that is the problem. Just will be relieved when it is over.
Message 15 of 19
To their credit BT seem to be trying their best to get everything solved.
Message 16 of 19
Had another visit from an Openreach Engineer today and according to his call it should be ported to SASA 1 but is ported to an unknown SASA.
I have to wait another 48 hours for it (hopefully) to be finally fixed.
Message 17 of 19
Not fixed yet, I will now have to wait until 20th July when BT will call me with an update.
Message 18 of 19
Ours was eventually fixed but we had to cancel & reorder, on BT advice, because things were such a mess. Our problem also turned out to be SASA related, plus incorrect postcode. Anyway, all now working properly.
Message 19 of 19
After making a second complaint I have been informed that I can't get full fibre broadband at my address at the moment and was told by BT that I should never have been offered it as Openreach didn't have the proper infrastructure in place.
BT have given me a huge chunk of credit on my account for all the wasted time.
