Message 1 of 31
Fibre 2 and stuck on 55/10 line , losing the will to live!
Hi , I have recently rejoined from Vodafone as their customer service was horrendous…..I am now paying for a fibre 2 package but stuck on 55/10 line profile , I have had an engineer out to confirm who told me I had to contact but to change me to the product I am paying for.
6 hours on the phone with complete scripted run around , Saturday I made another call to BT as a last ditch before cancelling , she was very helpful and said she understood and her colleague would swap me over sat pm , she is calling me a Tuesday to make sure I am happy with the switch. Guess what nothing has happened again!
can a mod help please ??
thanks
30 REPLIES 30
Message 2 of 31
Re: Fibre 2 and stuck on 55/10 line , losing the will to live!
@RodGrover
Check to see what is actually available to your house, as you line may not support a higher speed.
Please edit out your phone number before you post the result, but leave the exchange name and cabinet number showing.
Message 3 of 31
can you also post your hub stats - hub manager/advanced setting/technical log/information
Message 4 of 31
Hi @RodGrover and welcome to our community.
I'm sorry you're have a few problems. If you can post the information requested by @imjolly and @Keith_Beddoe we'll try to help you.
Cheers
David
Message 5 of 31
Connection statusConnected
Connection typeFibre Broadband (VDSL)
Firmware versionv0.33.00.12274-BT (Mon Dec 27 16:35:30 2021)
Serial number+091298+2202022913
Downstream sync speed49.3 Mbps
Upstream sync speed10.0 Mbps
Network uptime0 days 23 Hours 31 Mins 23 Secs
System uptime0 days 23 Hours 32 Mins 57 Secs
Public Wi-fi statusActive
Message 6 of 31
Hi as I have now taken broadband without phone line that link doesn’t work - I was on the quicker one with Vodafone so I know the line will take it , always had 17mb upload 45-54 download
Message 7 of 31
Product nameBT Smart Hub 2
Fireware versionv0.33.00.12274-BT (Mon Dec 27 16:35:30 2021)
Board versionR01
GUI version1.74 12_11_2020
DSL uptime0 days 23 Hours 37 Mins 2 Secs
Data rate10.0 Mbps / 49.3 Mbps
Maximum Data rate20.1 Mbps / 48.8 Mbps
Noise margin12.9/6.0
Line attenuation4.9/15.3
Signal attenuation4.9/17.7
VLAN id101
Upstream error controlOff
Downstream error controlOff
Data sent / received2.1 GB Uploaded / 2.1 GB Downloaded
Broadband username[email protected]
Public Wi-FiActive
2.4 GHz wireless network nameRods
2.4 GHz wireless channelSmart (Channel11)
5 GHz wireless network nameRods
5 GHz wireless channelSmart (Channel36)
Wireless SecurityWPA2 (Recommanded)
Wireless modeMode 1
FirewallOn
MAC addressC4:E5:32:E9:11:34
Software variant-
Boot loader0.1.7-BT (Thu Nov 30 09:45:22 2017)
Message 8 of 31
Just done now
Message 9 of 31
Address 6, STAXTON on Exchange SHERBURN is served by Cabinet 1
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream HandbackThreshold(Mbps) WBC FTTC Availability Date WBC SOGEA Availability DateHigh Low High Low      VDSL Range A (Clean) RodGrover_0-1658685173384.gif
8062.5201956.1AvailableAvailable
80602018.853.2AvailableAvailable
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install ProcessFTTP on Demand
33050--Available--
ADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) Availability DateWBC ADSL 2+ADSL MaxWBC Fixed RateFixed Rate
Up to 2--1 to 3.5Available
Up to 1.5--1 to 2.5Available
0.5----Available
0.5----Available
Other Offerings Availability DateVDSL MulticastADSL Multicast
Available
Available
Exchange Product Restrictions StatusFTTP Priority ExchangeWLR WithdrawalSOADSL Restriction
N
N
Y
The exchange is not in a current fibre priority programme
WLR is currently available at the exchange
SOADSL is restricted at the exchange
FTTP is not available.
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
Actual speeds experienced by end users and quoted by CPs will be lower due to a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
The Stop Sale date for IPstream is from 18 Apr 2018.
In order to be eligible for handback, downstream speed should be less than Downstream Handback Threshold values.
If you decide to place an order for a WBC fibre product, an appointment may be required for an engineer to visit the end user's premises to supply the service
Mildenhall exchange:Only single order products are available and ADSL and ADSL2+ products are not shown as available.However for premises that can only be served by SOADSL, BT will continue to accept ADSL and ADSL2+ orders until SOADSL is available.
Thank you for your interest
Message 10 of 31
Possibly a poor quality line, or an internal wiring issue. Its below the handback speed so you need to report it as a fault. If you were on the wrong profile, the noise margin would be higher.
Internal wiring may be an issue.
What does your master phone socket look like?
