Message 11 of 31
Re: Fibre 2 and stuck on 55/10 line , losing the will to live!
Hi number 7 , I had a new line put in a year or so ago , I am just on the wrong line profile , but engineer confirmed I was on 55/10
Message 12 of 31
Also engineer said I was on the wrong profile should be 80/20 ? BT also confirmed I was in n 55/10 but didn’t understand what I was talking about , very frustrating but thank you for looking into
Message 13 of 31
Regardless of which profile whether fibre 1 or 2 it will not affect the attainable speed only the actual connection speed so your line currently is getting as fast as possible .  As dslchecker suggests your line may be able to get faster but that assumes there are no line problems
Are you connected to master socket?  Have you tried one thing to test so let with a filter and see if that improves speed
Message 14 of 31
I haven’t tried with a filter , engineer on Wednesday confirmed no fault but wrong profile. Yes I am connected to the master socket. Internet is working fine but 9 mb upload is capped due to the 55/10 line I have been put on? That’s what the engineer said.
Message 15 of 31
I agree that looks like on 55/10mb but as I already posted your attainable speed shown on your hub is best your line can get regardless of the package/profile you are on and it is only showing 48/49mb
Message 16 of 31
So I suppose the question is why did by accept my order for fibre 2 and why is the upload capped  at 9 mb whilst for the las 4 years I have enjoyed 17 ?
why have I been offered fibre 2 at more money than fibre 1 and only get fibre 1 ?
i M paying for fibre 2 , the but site still shows available to me etc … the whole situation is more frustrating than being with Vodafone.
sky is saying minimum speed 52 with 17/18 upload on my address/ line ? That’s what I gOt per this BTEpisode
Message 17 of 31
I have asked a moderator to take a look, now you have all the results.
I would suspect an impacted line.
Message 18 of 31
Thank you
Message 19 of 31
Hi @RodGrover, sorry you're not getting the connection speed you're expecting.
I've sent you a Private Message so you we can look into this further and fix this for you.
Cheers
John
Message 20 of 31
Hi John,
I have replied to PM
thanks
Rod
