Message 21 of 31
Re: Fibre 2 and stuck on 55/10 line , losing the will to live!
Thanks for taking my call today @RodGrover .
I'm glad I was able to sort this for you. Let me know if you have any other problems.
Cheers
David
Message 22 of 31
Thank you for sorting so quickly @DavidM
Message 23 of 31
Hi @DavidM
So  profile changed and i am now getting 18/19 mb upload but the download and synch speed havent changed?
Could you check this is correct please?
Rod
Message 24 of 31
Hi @RodGrover ,
Thanks for posting. can you post your hub stats please?
Cheers
David
Message 25 of 31
Hi, thanks for the quick response:
Connection statusConnected
Connection typeFibre Broadband (VDSL)
Firmware versionv0.33.00.12274-BT (Mon Dec 27 16:35:30 2021)
Serial number2.2E+09
Downstream sync speed49.4 Mbps
Upstream sync speed20.0 Mbps
Network uptime2 days 3 Hours 18 Mins 4 Secs
System uptime2 days 3 Hours 19 Mins 48 Secs
Public Wi-fi statusActive
Message 26 of 31
@RodGrover
looking back at your hub stats it does not show you can get any faster down speed yet dslchecker days you can get faster.  can you post stats from hub advanced settings.technical log/information and lets see what hub says is attainable speed
Message 27 of 31
Product name BT Smart Hub 2
Serial number 2202114211
Fireware version v0.33.00.12274-BT (Mon Dec 27 16:35:30 2021)
Board version R01
GUI version 1.74 12_11_2020
DSL uptime 2 days 3 Hours 34 Mins 18 Secs
Data rate 20.0 Mbps / 49.4 Mbps
Maximum Data rate 21.2 Mbps / 49.5 Mbps
Noise margin 6.3/6.1
Line attenuation 4.9/15.3
Signal attenuation 4.8/17.7
VLAN id 101
Upstream error control Off
Downstream error control Off
Data sent / received 2.1 GB Uploaded / 2.1 GB Downloaded
Broadband username [email protected]
Public Wi-Fi Active
2.4 GHz wireless network name Rods
2.4 GHz wireless channel Smart (Channel11)
5 GHz wireless network name Rods
5 GHz wireless channel Smart (Channel36)
Wireless Security WPA2 (Recommanded)
Wireless mode Mode 1
Firewall On
MAC address C4:E5:32:E9:11:34
Software variant -
Boot loader 0.1.7-BT (Thu Nov 30 09:45:22 2017)
Message 28 of 31
@RodGrover
with you up speed on 20mb you are certainly on Fibre 2 but your attainable speed is only 49mb as is your actual speed.  the attainable speed is just as it says and is not restricted by package - the attainable speed will be the same whether on fibre1 or 2.
hopefully mods will find cause of the low attainable speed and therefore actual speed
Message 29 of 31
@DavidM
please see stats as requested
thanks
Message 30 of 31
I'm just leaving the office here @RodGrover . I'll get to this tomorrow afternoon.
Cheers
David
