Message 11 of 26
Re: Fibre 2 speed 45mb ??
The screenshot of your hub stats shows that DLM has reduced your speed in an attempt to stabilise your connection.
Is there any noise if you carry out a quiet line test by dialling 17070 ?
Message 12 of 26
I have done the quite line test and there is no noise
Message 13 of 26
Have you been restarting the hub in an attempt to improve your speed?  DLM considers your line to be faulty and has taken action
Message 14 of 26
I haven't restarted the Hub in months, what is the DLM ?
Message 15 of 26
your connection time is only 2 days so hub appears to be dropping connection
your attainable speed is low compared your dslchecker estimated range are you able to connect to test socket with filter and see if that makes any improvement?
https://community.plus.net/t5/Library/FTTC-DLM-What-it-is-How-it-works/ba-p/1322799
Message 16 of 26
Dynamic Line Management is an automatic system that monitors every line and takes action to achieve the best speed possible commensurate with the line characteristics. If it detects instability or impairment, it reduces the speed to stabilise connection.
Your line would appear to be faulty, hence the reduced speed.
Message 17 of 26
I know where the main socket is but not sure about the test socket ?
Message 18 of 26
which master do you have and are you using master socket
Message 19 of 26
I had a problem at the end of last year where I was constantly loosing connection which was resolved by an engineer visit.
Message 20 of 26
Master socket 7
