Message 1 of 7
Full fibre install
Hi there.
just wondered if anyone can help me?  I ordered full fibre broadband a few weeks ago and was told that engineers would inspect outside my property in a few days. The next morning an engineer arrived and came into the house. He said that it all looked very straightforward and that he could complete stage one of the install while he was here. He fed fibre through the existing conduit and added another box beside the existing socket. There is no external box.  So that I had no loss in service he reconnected the copper line. He said that on 1 June when I switch over the engineer will come out again and complete the switch over.  I didn’t really understand the amount of work involved in switching over and I don’t really want an external box. Is this really necessary? Also the external wall (where my socket is) is on the driveway which we have recently had resurfaced. Will this need to be dug up?
Thanks.
6 REPLIES 6
Message 2 of 7
Re: Full fibre install
You will have the external box as it is the Customer Splice Point. As the fibre has been pulled through the duct there is no need to dig.
Message 3 of 7
If the Engineers installed a CSP, which is necessary then I’d imagine he’s pulled in the UG ROC Cable already to it, so no your driveway wouldn’t need digging up.
The second Engineer will install an ONT inside and then a cable from there to the CSP the first Engineer installed.
Message 4 of 7
Starwire - Thank you for getting back to me. As my name suggests I am completely clueless so don’t know what a CSP or a ONT is! Could you please tell me? Happy that probably no digging up of my driveway will be needed but I assume that I will still need an exterior box? What does this look like?
Message 5 of 7
Pippincp - thank you for your answer - reassuring to know that my new driveway won’t need to be dug up!
Message 6 of 7
CSP is the external box where the internal fibre is spliced to the external fibre. ONT is the internal Optical Network Termination (optical modem).
Message 7 of 7
Thanks for explaining.
