Message 21 of 26
Re: Fibre 2 speed 45mb ??
you can remove the front as it just clips either side and test socket is then visible.  you will need a filter to connect to test socket and then connect rj45 cable to hub.  then repost hub stats
Message 22 of 26
Message 23 of 26
your attainable speed has not improved and you actual has come back at exactly same as before and it looks like as @licquorice suggested your line has problems and you are in a banded profile.  that does not explain why attainable is not within expected range
banded profile is explained in the previous link I posted
Message 24 of 26
Thank you for trying to help me, I guess I need to go back to BT and tell them that there IS a fault on the line.
Message 25 of 26
I have received 2 email notifications informing me that members have replied to my post but when I log in it says that I have insufficient privileges to view them??
Any suggestions please 🙏
Message 26 of 26
that normally happens if not logged in or the post has been deleted/moved
