Message 11 of 11
Re: Fibre 2 speed
@Anoojain wrote:
Thanks for (incorrect) assumptions re my home location .  I’m not sure this forum is helpful
Your property may only be 75M from the cabinet, assuming you have identified the correct cabinet that you are connected to, but the line from your cabinet does not necessarily take the most direct route from the cabinet to your property.
In any event if you feel that the forum is not giving you the answers that you want regardless of the answers being correct information I will not waste any more of my time trying to assist you.
