Message 1 of 11
Fibre 900 download/upload speed
Hi All,
Hope you can help, had an install of Fibre 900 Tuesday 9th Jan and know it can take a little while for everything to get sorted in terms of profile etc but I'm having issues with the speed and especially the upload speed from the router side
Here are some speed tests i have performed directly connected (via lan) to the router with everything else disconnected
I have also tried a PPOE connection from my laptop to the ONT, which gives a more promising result especially where upload is concerned
This leads me to believe the issue lies with the router? (smart hub2)
I have also performed a factory reset on the router and performed another speed test again wired over lan with only this device connected and still get the same result.
any help ideas would be greatly appreciated
Sam
10 REPLIES 10
Message 2 of 11
Re: Fibre 900 download/upload speed
you did not say if you had changed ethernet cable and made sure it is cat 5E or better
Message 3 of 11
Hi sorry,
It's cat 6 cable, i have tried multiple different cat 6 cables between router and laptop, with same result
when i did the PPOE test i used the same cable being used between the ONT and WAN port on the router
Sam
Message 4 of 11
@ulysees321
The Smart Hub 2 has an upload limit of 20Mbs, until a configuration change is sent to it by the BT management system.
This can take a couple of days, but you must leave the hub connected to the ONT all of the time, otherwise it will not see the config change.
If after three days of continuous connection, the upload does not change, then a moderator can be asked to assist, as there may be a data mismatch against the hub serial number.
Message 5 of 11
Thanks Keith,
Its normally connected 24/7 and has been since full fibre install on 9th, i only disconnected this morning for around 5 minutes to test the PPOE connection to the ONT,
Message 6 of 11
I have asked a moderator to help.
Message 7 of 11
Thank you, that is much appreciated
Sam
Message 8 of 11
Hi @ulysees231,
We can take a look into this for you and do our best to help you.
It will take us a few working days before we can get back to you but we will.
Thank you
DanielS
Message 9 of 11
Thanks Daniel
Message 10 of 11
Many thanks for your assistance, Issue is now resolved 🙂
