Message 1 of 4
Fibre Broadband Down - Possible Hardware Fault
Hi Everyone,
My fibre broadband isn't working. The lights on it are flashing like crazy, as seen in the video below:
https://www.youtube.com/watch?v=iEoXX-kGRMk
I've been through the connection guides, everything appears to be plugged in correctly. Nothing has changed. It stopped working whilst I was out and nobody else was at home.
I've looked at what the flashing lights could mean here: https://www.bt.com/help/landline/lights-on-the-openreach-modem
To summarise:
  • POWER:  Flashing (not covered in the guide to the lights)
  • PON and LOS: Both off (Not covered in the guide)
  • PORT1-PORT4: Flashing (Data is being transmitted through the port, possible connection problem)
  • TEL 1-2: Flashing (Fibre home phone line is not activated.)
As someone who works from home 2 days a week, this will be a problem for me.
I'm keen to get this fixed as soon as possible. Any help would gratefully be received. Thank you for any help or guidance you can offer.
Jonathan
3 REPLIES 3
Message 2 of 4
Re: Fibre Broadband Down - Possible Hardware Fault
Power cycle the ONT, if that doesn't work report the fault to customer services.0330 1234 150
Message 3 of 4
TBH , any guide  explaining the meaning of the ONT lights works on the proviso that it’s not faulty , TBH , yours  looks broken, as stated , you could  try power cycling it ( unplugging from the power , leave a short while and reconnect ) this may restore it to service, but if it doesn’t you would need a visit from Openreach arranged by reporting the problem to your ISP ( which presumably is BT if posting here on a BT Consumer forum )
Anonymous
Not applicable
Message 4 of 4
Do you have a redundant battery backup for the discontinued voice service service? If so you can try bypassing that.
If not & power cycling doesn't help, check the voltage/current of the ONT's PSU. Most kit seems to operate on 12V so have a hunt around for an old router, or other piece of kit that may have a matching 12V adapter. Doesn't matter if the current is rated higher, just can't be lower. The tricky bit may be finding one with a matching jack connector.
