Message 1 of 8
Fibre Profile - Upload speed not changed
Hi
Recently upgraded from Fibre 1 to Fibre 2 as it was only £1 so I could get the higher upload speed, but it hasn't changed and sits at the Fibre 1 cap.
Any mods available to check my line profile?
Router stats below:
7 REPLIES 7
Message 2 of 8
Re: Fibre Profile - Upload speed not changed
Have you checked that the upgrade has been processed by going to MYBT and check package shows fibre 2
After check post back
Message 3 of 8
Thanks for the quick reply.
I ordered the upgrade on the 29th and it is now showing on my account as Fibre 2.
Message 4 of 8
I have Asked a mod to see if they can help you.  They will post here
Message 5 of 8
Hi @LEWIS4596
Welcome to the community and thank you for your post!
I am sorry that you're not seeing a change in your upload speed after upgrading to Fibre 2.  I have sent you a private message with instructions on how you can send us over your details and we'll look into this for you. See: Private messages
Thanks,
Robbie
Message 6 of 8
Hi @LEWIS4596, the order to fix your profile has now completed.
Please would you check and see if you are receiving the increased upload and let us know?
Cheers
John
Message 7 of 8
Hi John,
Thanks for the update, it reset this morning and has now gone up to 16.
Hopefully the download speed will now increase up to 61.
Cheers for getting it sorted.
Message 8 of 8
Hi @LEWIS4596, thanks for checking that and posting back. Great that the upload has improved to 16 🙂 and I'll go ahead and close the case I had on your account now.
Cheers
John
