Message 1 of 3
Full Fibre 100 upload speed only 10 mbs
I've been on Full Fibre 100 for  a couple of months. My download speed is what's expected i.e. 150 mbs, but my upload speed never goes above 10 mbs. BT advertise that the upload speed should be 30 mbs.  When I try to run the broadband performance test from the Smart Hub2 it fails with a message saying that the Smart Hub can not be contacted !
2 REPLIES 2
Message 2 of 3
Re: Full Fibre 100 upload speed only 10 mbs
Hi @ExEngineer and welcome to our community.
I'm sorry you're upload speed isn't as expected. I'll be happy to take a look at this for you. I'll drop you over a private message now so  you can get in touch.
Cheers
David
Message 3 of 3
Hi @ExEngineer, thanks for getting in touch with us and that we've fixed your upload fault. 🙂
Cheers
John
