Message 11 of 25
Re: Full Fibre 500 to Full Fibre 900
Try fast.com
Message 12 of 25
Showing just over 600 so I suppose my speed is more or less OK.  My package ios 900 with guarantee of 700, what is the normal or average speed I should be getting?
Message 13 of 25
@tmarsh12345 Your speed is below what you should be getting, have you made sure you are using CAT 6 cables?
Message 14 of 25
Yes, all cat 6.
Message 15 of 25
What does this speed test say
BTW Performance Tester (btwholesale.com)
Message 16 of 25
616/134
637/132
645/134
630/132
Message 17 of 25
Download seems low, mine never falls below 900, but then your upload looks high as mine is always about 115
Message 18 of 25
Logged a call with BT, they reckon it's because I have some wifi connections.  So I have to run the test without any devices connected.
Message 19 of 25
Tests done and nothing wrong inside, speed still around 600 so they are sending an engineer. Tried various speed testers today and all report 900+. Should I cancel the engineer visit?
Message 20 of 25
BT engineer called today, factory reset the router, said it was a rouiter software update corruption but speeds still sub 700.
