Message 1 of 25
Full Fibre 500 to Full Fibre 900
Just upgraded from Full Fibre 500 to Full Fibre 900.  After 2 days speed is averaging 500.  Does it take a while to come up to the guarranteed speed?  Around 700 I think.
24 REPLIES 24
Message 2 of 25
Re: Full Fibre 500 to Full Fibre 900
Have you tried power cycling the ONT, it worked for me when I went from 500 to 900 but it may have just been a coincidence.
Message 3 of 25
How would I do that?  What is ONT?
Message 4 of 25
@tmarsh12345 are you using a wired connection for these speedtests or are you using WiFi?
Note: You won't get full 900mb speeds using WiFi on the smarthub 2.
Message 5 of 25
Wired.
Message 6 of 25
The ONT is the fibre modem which you have connected to the hub probably with the red ended ethernet cable. Small white box with probably 3 green !ights
Message 7 of 25
Thanks.  So do I press a button?
Message 8 of 25
Just switch it off wait and then switch back on
Message 9 of 25
Did that but still just over 500.  Upload is averaging 115 which is about right I think.
Message 10 of 25
I have always used Thinkbroadband for speed testing and just tried a different site, getting just under 700, 670 - 690 so perhaps nothing wrong?
