Message 1 of 19
Full Fibre 900 Speed Issues
Hi all,
I've had full fibre 900 installed for one week now, and speeds achieved are way below what they should be.
Typically I see ~90Mbs download and 80Mbps upload.
Wired connection is no better than wifi.
The home hub did have a significant period without being switched off (more than three days). In the last day or so, it's been restarted a few times following use of the Troubleshooting Tool. This says there's no issue with the speed to the hub.
I have an engineer visit booked for one week's time, but if I can sort something out before then so much the better.
Thanks in advance.
Paul.
18 REPLIES 18
Message 2 of 19
Re: Full Fibre 900 Speed Issues
What speeds do you get here fast.com
You can also try the MYBT app
Message 3 of 19
Thanks for the response.
I just got 99Mbps on wifi using fast.com.
The My BT app tells me that the spped to the hub is 897Mb download and 112Mb upload; but doesn't say what it is to the device.
Message 4 of 19
No real point in saying the speeds you are getting from WiFi, there are too many variables that have nothing to do with the ISP
Message 5 of 19
Fair point. It's approximately the same using ethernet.
Message 6 of 19
Silly question, does your device have GbE ports or just 10/100 ports?
Message 7 of 19
Not at all a silly question as it prompted me to expand my knowledge a bit. So, I confirm the device does have GbE, but maybe it could still be limiting the speed due to hardware issues (as it is quite an old laptop)?
Message 8 of 19
is the laptop connected directly to the SH2? Or are you using any switches powerline adaptors etc?
Message 9 of 19
Yes, direct connection, and for a test all other devices disconnected.
Still sees a max speed of approx 200Mbps.
Message 10 of 19
To rule out the hub being the bottleneck, connect the laptop directly to the ONT and make a direct PPPoE connection from the laptop. See https://www.tp-link.com/uk/support/faq/921/  if you are unsure how to do that.
Username is [email protected]
Password is BT
