Message 1 of 14
Full fibre to house
Hello,
My satellite TV is becoming un reliable due to trees blocking the line of sight.
The dish has been moved numerous times to find a signal
I now wish to move to a streaming box, BUT the copper to house has insufficient band width at 68.
Due to a medical condition I really rely on the tv.
The newly built houses next door have full fibre to house.
BUT my house still has no date for the upgrade.
How can I get full fibre installed NOW?
13 REPLIES 13
Message 2 of 14
Re: Full fibre to house
68Mbps is more than sufficient for TV.
Message 3 of 14
68Mb is more than 10x the bandwidth required for a HD stream and will handle 2x4K streams without difficulty…68Mb seems more than adequate for your needs , as far as FTTP ‘now’ , BT don’t install network, they use Openreach , you can get FTTPod (fibre on demand) where you pay for the network construction costs ( often in the 10x of thousands ££’s) ,BT don’t offer this Openreach product so you would have to make enquiries with an ISP that does .
Message 4 of 14
Thank you for your response.
Sky person suggested that replacing a sky box and a mini sky box would require more
Yes I know BT don't
But open reach have no contact
Message 5 of 14
Sky person obviously clueless.
Message 6 of 14
if you have a sky main box and a mini that suggests you have SKYQ.  is your SKYQ connected to the BT router by ethernet or wifi?  if wifi then I would suggest you go to hub manager then wireless and change the 5ghz channel from smart to something other than 36 say 48 as SKYQ uses channel 36 and may have conflict
Anonymous
Not applicable
Message 7 of 14
Message 8 of 14
@SharonW56  I would be very careful what you believe from any of the ISP's.  Their support people are more sales people today and very often on commission to upsell.   They will quite happily sell you a Farrari just to go do the weekly shop if they think they can get away with it.
Message 9 of 14
The problem is the signal from the satellite dish is obstructed and there is no other suitable placement. Hence the need to ditch skyq and go for a streamer.
Message 10 of 14
You are not listening, your current broadband is more than adequate, you do not need full fibre.
Are you even a BT broadband customer?
