Message 1 of 6
Hub 3 capabilities
After 20 years I am moving from PlusNet as they are withdrawing their home phone offering.
I am considering BT fibre 300 with DV. I have managed to glean enough answers to safisfy my queries on DV but would like some feedback on the supplied hub (Smart Hub 3 ?) as follows:
Is there documentation available for the router ?
If not:
Can I set static IPs ?
Can I limit the DHCP pool ?
Can I have a separate guest account ?
Do BT utilise the TR_069 protocol ? (have had bad experiences with this in the past)
Ideally I would like to use my current router (TP Link) but I know that to use DV I have to use the BT hub. I want a 'one stop shop' should anything go wrong so using an alternative DV provider is a no go.
I have seen on this site very good posts on how to link my own router to the hub but, if the above answers are okay, I would prefer not to go down that route.
Thank you in advance
5 REPLIES 5
Message 2 of 6
Re: Hub 3 capabilities
If not:
You can't set static IPs on any router, that is a function of individual devices. If, however, you mean address reservation, then yes it supports it.
No
Yes, t is how they update the hub firmware.
Message 3 of 6
Thank you and, sorry, I did mean address reservation.
Message 4 of 6
There is a "guest" wifii account available in the management section. It is off by default.
Message 5 of 6
Thank you - I think that has sealed it for me
Message 6 of 6
Oops, sorry, my mistake. Yes it does have a guest network.
