Message 11 of 16
Re: Hub constantly dropping
You haven't got FTTP if it is not going to be available until 2026. I suspect FTTC is what you have.
System uptime only says how long the power has been connected and not your actual connection. I suspect you have an intermittant connection due to a fault on the line which needs investigating by an Openreach engineer.
Posting the full stats you accessed earlier (advanced settings/technical log) would show that.
Message 12 of 16
No i didnt restart the hub, but it dropped out three times that morning. When the master socket was moved  they re routed the  original cable.
Message 13 of 16
Quick update, i contacted BT today regarding the problem and was told the service provided could have been disrupted by the electricians who rewired the room and moved the master socket which they shouldnt have done. I have another engineer booked for Tuesday but this time they say they are sending me a network engineer instead of a home engineer, If i need to move the master socket i need to contact them for a socket move engineer. I was also tole i could get fibre halo 3 for an extra £5 a month that would give me better speeds, im reluctant as i still have this disconnection issue, agent said he cold guarantee fibre halo 3 with all new equipment set up for me would definately sort this disconnection problem, did sound like a sales pitch to me as i still have the same cable coming into the home through the same socket, not wanting to pay more for more of the same im holding fire, any ideas about this?
Message 14 of 16
wait until openreach visit on tuesday and then think about any changes if openreach still cannot fix problem
Anonymous
Not applicable
Message 15 of 16
There are so many variables it's hard to know where to start. I'd suggest that you start keeping a log of every disconnection. Time, whether the hub lights changed & whether after it comes back, the System & Network up times are the same or not.
It's not clear what the relevance of the TV is unless you were watching a subscription or IP channel & that continued to play. If that's the case then also include what happens to the TV each time you get a drop.
If the Network & System up times always match, I'd suspect a power supply issue rather than a line fault. That could be anything from a poorly wired socket, faulty AC adapter or the Hub itself.
As @imjolly says, do nothing other than keeping the log of events & see what Tuesday brings.
Message 16 of 16
This has just happened for me again, this is the log information if anyone can suggest a fix ?
15:35:36, 16 Dec.
Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
15:35:36, 16 Dec.
15:35:36, 16 Dec.
15:35:35, 16 Dec.
15:35:35, 16 Dec.
15:34:53, 16 Dec.
CWMP: HDM socket closed successfully.
15:34:53, 16 Dec.
CWMP: HTTP authentication success from pbthdm.x.x.x
15:34:53, 16 Dec.
CWMP: HDM socket opened successfully.
15:34:53, 16 Dec.
CWMP: session completed successfully
15:34:53, 16 Dec.
15:34:53, 16 Dec.
15:34:53, 16 Dec.
15:34:52, 16 Dec.
CWMP: Server URL: https://pbthdm.x.x.x; Connecting as user: ACS username
15:34:52, 16 Dec.
CWMP: HTTP authentication Fail from pbthdm.x.x.x
15:34:52, 16 Dec.
15:34:52, 16 Dec.
15:34:51, 16 Dec.
CWMP: Session start now, server: https://pbthdm.x.x.x, Event code: 4 VALUE CHANGE
15:34:51, 16 Dec.
CWMP: Initializing transaction for event code 4 VALUE CHANGE
15:33:43, 16 Dec.
NTP synchronization success
15:33:43, 16 Dec.
NTP Server: ntp.homehub.btopenworld.com
15:33:35, 16 Dec.
LTE Modem owl_tx_lte_set_rate_shaper_script command sent
15:33:34, 16 Dec.
15:33:32, 16 Dec.
WAN Sensing Auto sensing Complete, interface selected
WAN IPv6 Global unicast prefix / length: 2a00:23c4:c412:1f00::/56
15:33:28, 16 Dec.
WAN IPv6 Global unicast address allocated: 2a00:23c4:c412:1f00::1/64
15:33:28, 16 Dec.
WAN DHCPv6 events: BOUND
15:33:28, 16 Dec.
NTP synchronization start
15:33:27, 16 Dec.
WAN DHCPv6 events: INIT
15:33:27, 16 Dec.
DSL Link Up: Down Rate=78178kbps, Up Rate=20000kbps; SNR Margin Down=6.3dB, Up=9.5dB
15:33:27, 16 Dec.
15:33:27, 16 Dec.
WAN Sensing Auto sensing Running
15:33:27, 16 Dec.
Success - secondary DNS servers
15:33:27, 16 Dec.
Success - primary DNS servers
15:33:27, 16 Dec.
WAN connection WAN2_INTERNET_PTM connected
15:33:26, 16 Dec.
PPP: IPCP up
15:33:26, 16 Dec.
PPP IPCP Receive Configuration ACK
15:33:26, 16 Dec.
PPP IPV6CP Receive Configuration ACK
15:33:26, 16 Dec.
PPP IPCP Send Configuration Request
15:33:26, 16 Dec.
PPP IPCP Receive Configuration NAK
15:33:26, 16 Dec.
PPP IPCP Send Configuration ACK
15:33:26, 16 Dec.
PPP IPCP Receive Configuration Request
15:33:26, 16 Dec.
PPP IPV6CP Send Configuration ACK
15:33:26, 16 Dec.
PPP IPV6CP Receive Configuration Request
15:33:26, 16 Dec.
PPP IPV6CP Send Configuration Request
15:33:26, 16 Dec.
15:33:26, 16 Dec.
PPP: CHAP authentication succeeded
15:33:26, 16 Dec.
PPP CHAP Receive success : authentication successful
Selected:
All
Time and date
Message
15:33:25, 16 Dec.
PPP: LCP up
15:33:25, 16 Dec.
PPP LCP Receive Configuration ACK
15:33:25, 16 Dec.
PPP LCP Send Configuration ACK
15:33:25, 16 Dec.
PPP LCP Receive Configuration Request
15:33:25, 16 Dec.
PPP LCP Send Configuration Request
15:33:25, 16 Dec.
PPP: Received PADS
15:33:25, 16 Dec.
PPP: Sending PADR
15:33:25, 16 Dec.
PPP: Received PADO
15:33:25, 16 Dec.
PPP: Sending PADI
15:33:20, 16 Dec.
PPP: Starting PPP daemon
15:33:19, 16 Dec.
WAN Auto-sensing detected port DSL WAN
15:33:01, 16 Dec.
admin timeout from 192.168.1.69
15:32:56, 16 Dec.
SIP WAN DOWN
15:32:47, 16 Dec.
SIP WAN DOWN
15:32:47, 16 Dec.
15:32:47, 16 Dec.
15:32:45, 16 Dec.
15:32:45, 16 Dec.
15:32:45, 16 Dec.
WAN connection WAN2_INTERNET_PTM disconnected.[ERROR_NO_CARRIER]
15:32:44, 16 Dec.
PPP: Stopped PPP daemon(0,1,5)
15:32:44, 16 Dec.
PPP LCP Send Termination Request (User request)
15:32:44, 16 Dec.
PPP: IPCP down
15:32:44, 16 Dec.
PPP: LCP down
15:32:44, 16 Dec.
DSL Link Down: duration was 526585 seconds
15:32:41, 16 Dec.
Receive a DHCP request
15:32:40, 16 Dec.
WHW INFO A station (SmartHub2)IF[5G](0C:8E:29:7E:14:62):STA(0E:AD:DD:A7:60:75)(Legacy Device) join WHW infrastructure
15:32:40, 16 Dec.
WHW INFO A station STA(0E:AD:DD:A7:60:75) leave WHW infrastructure
