Message 31 of 35
Re: I just moved to BT Fibre 1 - speeds lower than acceptable
@licquorice  I was trying to put it in simplistic terms rather than go into all the technicalities. I know there is a lot more to overheads but why confuse someone. I prefer to just give them something they can understand.
Message 32 of 35
Err no. Overheads have absolutely nothing to do with acks.
Message 33 of 35
Thanks all of you ( @licquorice @pippincp @imjolly
I guess I am currently fighting a concluded battle. I will investigate further and get back if I find anything worth continuing with.
Kind regards
Message 34 of 35
@licquorice  Err yes they do. For instance a speed test only uses the first three layers of 7.
Message 35 of 35
When in a hole stop digging
