Message 1 of 4
IPv6 prefix not provided on new FTTP
New FTTP connection this morning and IPV6 just wont work, was working fine with old provider but nothing here.
I have set it up to use the existing pppoe connection - DHCPv6 (and tried auto) - it fills in an ipv6 local FE address but all checkers fail to have an external ipv6 address ?
I know this is supposed to be enabled by default but some have found its not been the case, can someone kindly check this for me please.
many thanks.
Tags (1)
3 REPLIES 3
Message 2 of 4
Re: IPv6 prefix not provided on new FTTP
IPv6 is enabled on all connections, make sure your device is configured correctly. BT use /56 PD
Message 3 of 4
ive seen reports on here where the ipv6 wasnt setup correctly their end though, also i had it working on previous provider fine as i stated
Message 4 of 4
TP-Link support was eventually able to solve this for me.  The correct settings are shown as *xxx* below:
IPv6 - *Enable*/Disable.  Enabling gives the following options:
- IPv6 Connection Type - choose from Dynamic IP, *PPPoE*, 6to4 Tunnel, or Bridge.  If PPPoE is selected it asks whether to use the same account as IPv4 - *yes*
- Get IPv6 Address  - choose from Stateful, Stateless, *Non-Address* or Auto
- Prefix Delegation - *yes*/no
- Obtain DNS automatically - yes/*no*.  *Use Google's IPv6 DNS server addresses as follows:  primary - 2001:4860:4860::8888 and secondary - 2001:4860:4860::8844*
- Assigned Type - choose from ND Proxy, SLAAC+Stateless DHCP, DHCPv6, or *SLAAC+RDNSS*
- Firewall Rules - *none required*
found these settings and now its working as expected.
Solved: IPv6: config help needed for third party router - BT Community
