Message 11 of 13
Re: Installation of Fibre 2
The original line went to the side of the house, and then to the hallway, whereas the TV room is at the front of the house. Will they perhaps then run it from the side round to the front on the outside and then through? Otherwise it would leave it all in the hallway some distance away from the TV.
Message 12 of 13
The ONT can be placed practically anywhere on an outside wall, have a word with the install engineer, they usually do thier best to accomodate you. If you need DECT phones BT will supply 2 or 3 (can't remember specically) FOC. You would need to request them though.
Message 13 of 13
@pippincp
You can get 1 free advanced phone with Alexa or 2 basic essential phones or an adapter for existing phones
