Message 1 of 5
Interleaved
Hi, had a Openreach engineer come round on Wednesday due to BT not giving me the speed they say ,should be at least 70mb ,however it’s been running at 65 for some time whic I just settled on ,what triggered me was after the storm power cuts I was getting back to 74 for a day so relished it’s attainable ,so now he changed faceplate and did a DLM reset which has made it interleaved, a level 2 engineer was due for tomorrow but cancelled, basically how long would it take to go back to fast path which should get the speed back up - hardware = Asus AX86U + Vigor 130 ( home hub is even slower )
ECI can
Type ? for command help
> vdsl status
  ---------------------- ATU-R Info (hw: annex A, f/w: annex A/B/C) -----------
   Running Mode            :      17A       State                : SHOWTIME
   DS Actual Rate          : 63347000 bps   US Actual Rate       : 17580000 bps
   DS Attainable Rate      : 73754712 bps   US Attainable Rate   : 17588375 bps
   DS Path Mode            :  Interleave    US Path Mode         :  Interleave
   DS Interleave Depth     :      932       US Interleave Depth  :      221
   NE Current Attenuation  :        8 dB    Cur SNR Margin       :        6  dB
   DS actual PSD           :    -2.-8 dB    US actual PSD        :    -2.-8  dB
   NE CRC Count            :        0       FE CRC Count         :   108346
   NE ES Count             :        0       FE  ES Count         :    48509
   Xdsl Reset Times        :        0       Xdsl Link  Times     :        1
   ITU Version[0]          : fe004452       ITU Version[1]       : 41590000
   VDSL Firmware Version   : 05-07-09-0F-01-07   [with Vectoring support]
   Power Management Mode   : DSL_G997_PMS_L0
   Test Mode               : DISABLE
  -------------------------------- ATU-C Info ---------------------------------
   Far Current Attenuation :        7 dB    Far SNR Margin       :        6  dB
   CO ITU Version[0]       : b5004946       CO ITU Version[1]    : 544eb206
   DSLAM CHIPSET VENDOR    : < IFTN >
Thanks in advance
4 REPLIES 4
Message 2 of 5
Re: Interleaved
it won't go back to fast and as on ECI cab (i assume that is ECI can) there is no speed boost from G.INP
however if you just stay connected 24/7 your speed may improve in 7/10 days
Message 3 of 5
Re: Interleaved
But it was on fast path previously, BT gave me a guarantee of 70 as well ,looks like I may be going down the hand back route ,and yes it’s ECI cab ,thanks
Message 4 of 5
Re: Interleaved
BT like other ISP will give a connection speed range not an exact speed  you can check by enter phone number here
Message 5 of 5
Re: Interleaved
Yes aware of that site and should be  80 -  74 , there’s something not right that I do know and it’s at there end ,my equipment and cables are all good quality, thought that with the DLM being reset it would start to improve
