Message 11 of 18
Re: Internet REIN
not on all of them but a good few of them they gave me a new power wire yeah
Message 12 of 18
Re: Internet REIN
Not just the power wire but the actual power brick....
Message 13 of 18
Re: Internet REIN
sorry i'm confused, i don't have a power brick? never have done, have smart hub 2, just have one power lead with a big plug attached to it, and then the cable from the master socket into the router
Message 14 of 18
Re: Internet REIN
That is what I meant, the big plug.
Message 15 of 18
Re: Internet REIN
Perhaps the power socket that the hub plugs into is faulty, try plugging a lamp into it and check for flickering
Message 16 of 18
Re: Internet REIN
Might be worth investing in a surge protection extension lead.
Message 17 of 18
Re: Internet REIN
i've had one still not solved the issue
Message 18 of 18
Re: Internet REIN
our internet drops every night at 9.30pm, normally when we are watching netflix, i’m guessing it’s the streetlights ??
