Message 21 of 53
Re: Internet connection loss
Please let us know how you get on with the WiFi disc @barryconway51
Leanne 🙂
Message 22 of 53
WiFi disc set up. Everything ok. I am away for a few days but will let you know how it goes after a week or so, thank yiu
Message 23 of 53
I have had to reboot the BT Hub on 26/9 and 30/9 so looks like the problem  continues. Don't know where to go from here. However I have now plugged in a USB WiFi adapter/dongle in my laptop to see if that makes any difference. Thanks for now.
Message 24 of 53
I have reported  it as a fault again. This time with the help of a BT Guide we did a factory reset. However the situation is still the same - no resolution yet I'm afraid. Even get internet disconnection when I am out!
Message 25 of 53
Hi there @barryconway51
I'm sorry this has happened again and the factory reset has not resolved the connection dropping. To see what is needed next, I would advise getting back in touch with our broadband tech team and they will let you know the next steps 🙂
Please let me know how you get on.
Leanne.
Message 26 of 53
Hi Leanne_T
After reporting that the problem is still ongoing, BT sent a Home Expert here today. As we have already eliminated everything in my home set up, he changed the ethernet cable between the ONT and the hub, Everything working ok when he left. Will have to wait to see progress.
Regards
Message 27 of 53
Thanks for keeping us updated @barryconway51.
I hope that is all sorted for you now, but please keep us posted if anything changes again.
Michael
Message 28 of 53
Message 29 of 53
I am still getting the same problem - internet disconnections every few days - needing to reset hub. BT expert has been here, changed ethernet cable ONT to hub and was happy with my home set up and suggested if the problem continues it may be in the Openreach network. I have tried ethernet cable to Sky box so not a WiFi fault.  However my laptop was in for repair for over a week (battery not charging) and the internet did not disconnect during that period. I cannot understand how my laptop could cause all devices to be affected though. Thanks for any suggestions on what to do next.
Message 30 of 53
Does your laptop network adapter have MAC randomisation?
