Message 41 of 53
Re: Internet connection loss
Hi, Yes I have just disabled MAC randomisation on the network adapter earlier this morning. I will keep you informed on progress. I also used the laptop without charger. I had an internet drop out this morning and did a hub reset. So l have now eliminated the charger
Message 42 of 53
Hi Barry.
It might be worth raising the issue again, as Openreach have only recently been given the go ahead, to actually upgrade the ONT. Mine was only installed on Friday afternoon but so far, I haven't noticed any drops in connectivity.
Regards
John
Message 43 of 53
Have you actually read the thread? No drops were experienced whilst the laptop was not connected.
Message 44 of 53
Hi licquorice. Yes the internet did not disconnect in the period when my laptop was in for repair
Message 45 of 53
Hi @barryconway51
Seems a strange one, but I'd like to see if we can check if there is something interfering with your router from your laptop.
I'll send you private message. Please check your inbox and get back to me when you can.
Ali
Message 46 of 53
Internet dropped again yesterday with MAC randomisation disabled so no solution there I'm afraid. Thankyou for the suggestion.
Regards, Barry
Message 47 of 53
Yes tried that but internet dropped out again yesterday so still the same problems
Message 48 of 53
Hi John
How is your internet connection since the new ONT was fitted?
Regards,
Barry
Message 49 of 53
Hi Barry
I don't want to tempt fate, but there has been a distinct improvement, in that the intermittent drops seem less frequent. It's still not quite right, so I have just installed an EE Smart Hub Plus Router, but as I'm not a techie, I have been having some teething problems. 😂  Watch this space. 🤔
Regards
John
Message 50 of 53
Hi John
Good to hear that. My Hub has been OK for a while too. It looks like it was probably congestion on the WiFi channel(s)
Regards
Barry
