Message 1 of 15
Internet stuck at half speed IP reset
Hi there I'm still having a number of problems even after the engineers have been out fixed the issues of the internet dropping but now I'm stuck at half speeds . I think I need an ip reset if at all possible
14 REPLIES 14
Message 2 of 15
Re: Internet stuck at half speed IP reset
Can you post your hub stats   if sh2  then go to hub manager/advanced settings/technical log/inforrmation
Message 3 of 15
Product code: Hub
Serial number:+091301+1935012380
Firmware version:v0.33.00.12274-BT
Firmware updated:Mon May 30 10:14:54 2022
Board version:R01
GUI version:1.74 12_11_2020
DSL uptime:3 days,17 Hours46 Mins59 Secs
Data rate:1.732 Mbps / 25.265 Mbps
Maximum data rate:1.732 Mbps / 24.643 Mbps
Full Fibre (FTTP) Mode:Off
Noise margin:6.5 / 2.8
Line attenuation:9.2 / 22.5
Signal attenuation:9.2 / 22.8
VLAN id:101
Upstream error control: Off
Downstream error control: Off
Data sent / received:1.5 GB Uploaded / 44.4 GB Downloaded
Broadband username:[email protected]
Public Wi-fi status: Activated
2.4 GHz wireless network name:BT-FRA6CF
2.4 GHz wireless channel: Smart (Channel 1)
5 GHz wireless network name:BT-FRA6CF
5 GHz wireless channel: Smart (Channel 36)
Wireless security:WPA2
Wireless mode: Mode 1
Firewall: On
MAC address:F0:86:20:51:E8:7B
Software variant:-
Boot loader:0.1.7-BT (Thu Nov 30 09:45:22 2017
Message 4 of 15
I normally get around 39 download and around 5 upload cheers
Message 5 of 15
There is nothing in the stats you posted which suggests you can get any faster connection and with noise margin down at 2.9db you are already getting a boost as normal noise margin is 6db
Unless you are on digital voice can you enter your phone number and post results
Message 6 of 15
Address 5, BUXTON on Exchange BUXTON is served by Cabinet 39
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream HandbackThreshold(Mbps) WBC FTTC Availability Date WBC SOGEA Availability DateHigh Low High Low      VDSL Range A (Clean)
VDSL Range B (Impacted)
49.9358632.4AvailableAvailable
48.932.47.95.727.4AvailableAvailable
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install ProcessFTTP on Demand
33050--Available--
ADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) Availability DateWBC ADSL 2+WBC ADSL2+ Annex MADSL MaxWBC Fixed RateFixed Rate
Up to 17--10 to 19.5Available
Up to 17Up to 1.510 to 19.5Available
Up to 7.5--6.5 to 8Available
2----Available
2----Available
Other Offerings Availability DateVDSL MulticastADSL Multicast
Available
Available
Exchange Product Restrictions StatusFTTP Priority ExchangeWLR WithdrawalSOADSL Restriction
N
N
Y
my number didn't seem to work but i put in my address and this is what i got. confused as had a problem for a few months now and bt support hasn't been helpful. Hope this helps Dan G
Message 7 of 15
Possible disconnection on one wire of the cable pair.
Message 8 of 15
Are you on digital voice
Message 9 of 15
As in the cables for the internet router are not in right? sorry if I'm being stupid.
Message 10 of 15
I am yes
