Message 11 of 14
Re: Is Fibre 2 Full Fibre?
A fantastic thread here guys.
All the correct information and everything the OP asked for. Just what the community is all about.
Cheers
David
Message 12 of 14
Full Fibre 100 ‘speed’ is actually 150Mb , and because it’s FTTP , that’s the speed you get , no distance related speed reduction you may get with ADSL or FTTC , the pricing images posted suggest that there is a £2/month difference between Fibre 2 and Fibre 100 , but very confusingly, the £2 doesn’t provide an extra 20Mb speed , but nearly doubles it from 80Mb to 150Mb.
F100 may still be more that needed , and any saving is helpful , but it’s significantly ‘faster’ than its name suggests
Message 13 of 14
Hi mate,
I know this is an old post but just thought I’d share my recent experience.
I have been on Fibre 2 for around 30 months (6 months into a new 24month contract) paying £29.99pm and getting a download speed of 66-73mbps
I randomly browsed the site after looking at my bill. In the ‘your products’ section it has a ‘your offers’ tab, I clicked it and seen I had an upgrade offer to Full Fibre 100 getting 150mbps for no extra charge, free installation & same price I have been paying.
for the same price it’s quite a big speed jump which I’m made up with.
I was confused after ordering the upgrade as I received an installation date and that the engineer would need to drill a hole in the wall to get the cable in.
This suggests the Full Fibre 100 is provided via a different cable than the previous Fibre 2. I can only assume
1)  It’s sent via a Fibre Optic cable, or
2) That Fibre Optic has recently been laid in my area, or
3) That Fibre 1 & 2 are provided via an old copper cable
I dont know whether the free upgrade is due to me being a returning customer when signing a new contract or if Fibre Optic will replace the old cables. Either way, more than doubling my speed for the same price was a no brainer.
Message 14 of 14
Fibre to the cab , FTTC and fibre to the premises FTTP can both deliver 40,55,80Mb , only FTTP can deliver faster speeds ( ignoring Gfast ) , BT differentiate calling FTTP ‘full fibre’ .
Years ago , Virgin called their hybrid fibre/copper broadband ‘fibre’ , so others using a similar fibre/hybrid system used the same term  to advertise their FTTC products , and TBH , if someone was sold 40 Mb ( for example ) and obtained that speed , does it matter if it’s FTTC or FTTP  ?.
Now that  FTTP  is becoming commonplace, full fibre or similar is the term to look for FTTP  , and if both are available FTTP is the default network, even if 40Mb is ordered.
