Message 1 of 13
Junction box
Hi all
just been round the side of the house and see the Junction box where the openreach cable arrives at the house and passes up to the loft where the main phone and broadband connect.
Is it worth contacting BT and would it be a chargeable job?
I can’t say that it is effecting my speeds
thanks
12 REPLIES 12
Message 2 of 13
Re: Junction box
Are you getting problems with your phone?  If not unlikely you will get openreach as 'not broke don't fix it'
Message 3 of 13
Re: Junction box
Thanks. No problems at all. Just wondered if it was worth preempting future problems
Anonymous
Not applicable
Message 4 of 13
Re: Junction box
Have you taken the cover off to take the pic or is it missing?
Message 5 of 13
Re: Junction box
What problems are you expecting? There is absolutely nothing wrong there to fix as long as the cover isn't missing as @Anonymous  has mentioned.
Message 6 of 13
Re: Junction box
The cover is missing. Thanks
Anonymous
Not applicable
Message 7 of 13
Re: Junction box
Couldn't be sure with the limitation of image size on this forum but it looked like the retaining screw had rusted through. In that case report it to BT as once water gets in there you will get problems. In the meantime I'd cover it with a plastic bag secured with an elastic band.
Message 8 of 13
Re: Junction box
Thanks very much @licquorice @Anonymous @imjolly
I’ll call in the morning. I assume that it would be a non-chargeable call-out?
Message 9 of 13
Re: Junction box
Yes, but don't hold your breath waiting for Openreach to come and fix it though. It shouldn't cause any problems in the short term as the connections are jelly crimped. Has the lid disappeared? If you can find it you could just tape it on with gaffer tape.
Message 10 of 13
Re: Junction box
Is the box sheltered like in outhouse or garage as does not look like any signs of damp
