Message 1 of 8
Line Reset required
Hi - Could a Moderator assist with a line reset please? I have been  stuck on a slow speed for over a month and in the past I have been able to get a moderator to perform a line reset which has solved my problem?
Thanks in advance for your help
7 REPLIES 7
Message 2 of 8
Re: Line Reset required
can you post your current hub stats please
Message 3 of 8
If the line is needing reset every month that would tend to indicate a fault somewhere.
Message 4 of 8
Hi - Line has been at 55Mbps consistently for 2 years. Last month it dropped to the following.............when this happened before, a line reset has fixed the problem.
Firmware updated:Tue Jul 9 13:52:28 2024
Board version:R01
GUI version:1.80 11_07_2023
DSL uptime:1 days,10 Hours03 Mins44 Secs
Data rate:9.997 Mbps / 48.998 Mbps
Maximum data rate:15.678 Mbps / 59.316 Mbps
Full Fibre (FTTP) Mode:On
Noise margin:9.4 / 8.1
Line attenuation:9.6 / 19.6
Signal attenuation:9.6 / 21.3
VPI/VCI:0/38
VLAN id:101
Message 5 of 8
you uptime is only 1 day suggesting there is a line problem unless you are manually resetting to try and improve the speed.  continual manual/line resets will actually make your connection speed worse as the DLM takes action
provided you don't have DV have you checked for line noise causing a problem
Message 6 of 8
Hi - I am not manually resetting the line. I have had this exact same problem 4 times over the past years (normally when I renew my BT contract my speed drops from 55 to 48) and each time a line reset has got my speed back to 55Mbps and it has stayed there - could you please perform a line reset and this will solve the problem for me, like it has in the past? I suspect the firmware update in July may have triggered the reduction so if you reset the line it will fix the problem.
Thanks in advance.
Message 7 of 8
if your connection is continually dropping and no manual reset then you need to find the cause before any reset
Message 8 of 8
Thanks. 2 years ago I got the line reset and it has been fine up until July. It is quite common for my line to drop every 4 or 5 days and that has been happening over the past 2 years and the speed remained at 55Mbps. All I need is a line reset and I am sure the problem will be resolved as it has been in the past. Can you action please? If I contact BT they will tell me that 48 Mbps is within the guaranteed range and they won't investigate further
Thanks in advance
