Message 11 of 24
Re: Maximum available speed halved in a week.
I told you 29mb
Message 12 of 24
Right, then you have a fault that needs to be reported. You are just confusing everything by reference to the checker and renewing contract which is totally irrelevant.
Message 13 of 24
Well I have made 10 phone calls and am told the same thing, if whatever Openreach report as my max speed that is all they can offer me.
Message 14 of 24
The estimates you are getting of 27mb is based on your current connection stats and as @licquorice posted you have a line fault
Do you have a home phone not on digital voice?  If so check for dial tone as the reduction in speed can be caused by a wire disconnected in your phone socket
Message 15 of 24
Forget trying to renew your contract, have you reported the fault?
Message 16 of 24
I don't hear any noise on the line, an Openreach engineer came out yesterday said he found a fault at the exchange and fixed it.
He then done a line check and said I should be able to get 85mb.
But like I say I cant get a contract for any speeds over 30mb with any ISP unless I change my flat number to nextdoor.
Message 17 of 24
Yes, BT don't even seem to recognise it as a fault, I am being told they can only go by the speeds reported by Openreach and they cant do anything.
Message 18 of 24
If you don't have digital voice and you cannot hear the dial tone on your phone then you need to report a phone fault not a broadband fault. Get phone working and broadband speed will return to'normal'
Message 19 of 24
There is nothing wrong with the dial tone, not even any noise or static.
Message 20 of 24
Can you post a screenshot of the hub stats?
