Message 11 of 15
Re: Neighbours get faster speeds
I don't hear any noise on my line.
Message 12 of 15
The stats confirm fibre 2 and as @licquorice  posted you are in a banded profile. As you have 20 days stable connection I have asked a mod to help you get speed back to  near attainable speed.  They will post here
Message 13 of 15
Thank you very much for your help.
Message 14 of 15
Hi @cecepih706,
I can get this looked into for you. I'll send you a private message that you can reply back to me on.
Your message will then go to one of my team. We all work for BT.
Also, thanks for highlighting this to me @imjolly
DanielS
Message 15 of 15
Just wanted to update this thread to say BT sorted it all out thanks to Mods and forum helpers. I've gone from 35mbps to 60+mbps after it was un-banded. Looks like the cause of disconnects was a dodgy home plug.
Thank you!
