Message 1 of 20
New FTTH install cables.
Hello, Next week I'm supervising  my Daughters FTTH install while she's away and because of the lack of suitable power sockets there's only one place the engineer can install ONT unit which is luckily where the existing pstn cable comes into the property but the red Cat5 cable BT has delivered is not long enough to run from the ONT to the Smart hub2 which is at the moment in the best place for good wifi coverage throughout the house.
So rummaging though some of my old stuff BT have sent over the year I've come across an unwrapped 10m STP ethernet cable with the code G9213ZC030-22 on the polythene wrap - the questions are  1 will this work OK from the ONT to the Smart hub instead of the one BT has sent and 2 do you think the engineer will be happy to use it ?
Sorry I can't find where to upload a pic.
Cheers,
Del.
19 REPLIES 19
Message 2 of 20
Re: New FTTH install cables.
You can use any Cat5e upwards cable. The colour is irrelevant. The engineer should have no problem using it.
Message 3 of 20
@djh22
Amazon show the same thing, and say its a CAT5e cable, although I would be surprised, as the one I have is quite thin.
Message 4 of 20
Thanks gg30340.
Message 5 of 20
Thanks Keith, yea that's the one and thinness of the cable is the bit that worries me,I think I got mine with an old YouView box so not sure if it will work from the OTN to Hub. I guess I'll have to source another cat5 cable from somewhere or maybe join 2 shorter ones with the old rj45 connectors.
Best,
Message 6 of 20
Give it a try but be prepared to have to use an alternative,  You can pick them up cheap enough from ebay.
Message 7 of 20
Thanks pippincp, I agree, just trying to make sure all goes smoothly on Thursday.
Cheers.
Message 8 of 20
@djh22
I have one of those cables and tried to use it to feed a POE wireless access point, and found that only four wires were actually connected.
Message 9 of 20
I wouldn't join two cables. The cable you have is a Cat5e cable. The STP refers to the type of shielding that it has.  It should work OK but if you are worried about it you can get a 10 meter Cat5e Ethernet cable on line for about £10.
Message 10 of 20
Thanks everyone for your very helpful replies, I think I'll order a new 10m cat5 cable just in case.
Cheers.
