Message 11 of 20
Re: New FTTH install cables.
Pretty sure that won’t work as it’s a Cat5 cable, i.e. only 2 pairs and not a CAT5e 4 Pair.
Can you not just use an Electrical Extension Cord so they can install the ONT to where the Router is/will be?
Message 12 of 20
It has to go under a carpet in front of a fireplace so an electrical extension cable would be a bit bulky, thanks anyway though.
Message 13 of 20
I'm thinking of this on Amazon -
RJ45 Cat5E-CCA UTP Patch 26 AWG cable 10m
Message 14 of 20
The CCA suggests the cable is Copper Coated Aluminium rather than simply fully copper wires. I always try and avoid CCA due to past problems and pay a little more for full copper.
Message 15 of 20
I’d concur with 36ULW.
I’ve got one of those cables on an old BT TV box. It’s 2 pair only TX cable, limited to 100Mb/s max. You’ll need 4 pair cat 5e or cat 6 for the ONT but the length could theoretically be up to 100m.
Message 16 of 20
Thanks everyone, your excellent advice has been noted and I have sourced a more compliant cable.
Cheers,
Del.
Message 17 of 20
Can’t you just use a double mains adaptor where the router is? You can get flat ones from Amazon just google 3 way mains extender
My engineer ran the fibre cable to the back bedroom where the router was and put the ONS there.
Message 18 of 20
Thanks Microvent, yes I could and that would be my son-in-law's preferred position for the ONT, but there are also  unmovable obstacles in the way such as a large fish tank and a large old fashioned fire place and other places where it wouldn't be appropriate to pin cables.
Cheers.
Anonymous
Not applicable
Message 19 of 20
I'm a bit late to this thread, but also got led astray using the cable pictured - two of them from my Useful Bits Box, originally from BT.
It took me a while to realise that they were the reason my laptop was only syncing to the Hub @ 100Mbps. I thought one might be faulty, but became suspicious when the second did the same. A third, different type, cable correctly synced @ 1000Mbps.
Those two cables went in the (recycling) bin - to avoid confusion in the future!
Message 20 of 20
Good advice, thanks Paul.
