Message 1 of 9
New install red PON light
Just had a new install and the lads could not get my ont PON light to go green it’ was red then flashing green and after a few phone calls it went back to red,and as they left they said some else would have to fix the issue.
question is how long will have to wait for fix?
8 REPLIES 8
Message 2 of 9
Re: New install red PON light
How long is a piece of string? Depends entirely what the problem is and what resources Openreach have to fix it, nobody here will have any insight.
Call the FTTP team and they might be able to update you 0800 587 4787
Message 3 of 9
Thanks I will call in the morning, the install team chance to update info from their end
Message 4 of 9
If the number diverts to normal customer services (which it does if busy), just hang up and try again later.
Message 5 of 9
Hi @Friely and welcome.
Please keep us updated on how things go
Cheers
David
Message 6 of 9
@licquorice how do I know if I’m diverted to cs is it autobot telling to press 1 for phone/broadband etc?
Message 7 of 9
I assume so.  I've never had cause to call the FTTP team but know that it does divert when busy.
Message 8 of 9
@DavidM  Afternoon update 2 Openreach lads have been here all day and found that none of the fibre had been connected at  a pole 200 metres away and had to connect 12 of them to get it up and running!.
 I can get online and speed seems good
Now I’m just waiting for my account to update as it still says I’m waiting on the engineer !.
Message 9 of 9
Thanks for the update @Friely .
I'm glad to hear your finally connected. The account should sort itself out but if there are any problems let me know.
Cheers
David
