Message 1 of 14
New smart hub
I currently have Halo 3 broadband using FFTC and I’m being upgraded to FFTP week. I’ve just received a text informing me of a delivery tomorrow. I assume that it’s a new Smart Hub and disc. Is a new hub necessary because I’d have to set up all of my devices with a new addresses? Is it possible to change the address of the new hub within manager?
13 REPLIES 13
Message 2 of 14
Re: New smart hub
yes change your new SH2 to have the same SSID and wifi password of existing hub and devices will connect automatically
Anonymous
Not applicable
Message 3 of 14
Re: New smart hub
Are you currently using a smart hub 2?
If yes then no need to change anything.
On install day all you'll notice is faster speeds
Message 4 of 14
Re: New smart hub
@Anonymous
the older/initial SH2 did not have WAN port so did not work with FTTP
Anonymous
Not applicable
Message 5 of 14
Re: New smart hub
Really?
Thought the SH2 was released to cater for the full fibre roll out.
Pretty sure it hasn't changed
Message 6 of 14
Re: New smart hub
Yes, I’m using Smart Hub 2. I’ve noticed in the manager that there is a tick box marked “FTTP”. Will  have to fill that box or will it be automatic?
Message 7 of 14
Re: New smart hub
If your SH2 is FTTP enabled then you will need to toggle FTTP on.  as your hub is FTTP capable you may not be sent an new hub
Message 8 of 14
Re: New smart hub
You need to select the FTTP tick box. This changes "Red" port on the SM2 to become the WAN port. If you are not using the port at the moment you can change it now if you want. If you are using it as an Ethernet port to a device you will need to use a different Ethernet port after changing it.
If you have a SM2 all that will be sent out to you is an Ethernet cable so that you or the Openreach Engineer can connect the ONT to the SM2 WAN port.
Message 9 of 14
Re: New smart hub
Does that mean that I’ll have to initially log on using one device, to access the hub manager?
Message 10 of 14
Re: New smart hub
Yes you will need to log onto the Hub manager and tick the FTTP box.
