Message 11 of 21
Re: New to BT (from Virgin)
We'll agree to disagree.
I know people who have done it with TPlink systems and ASUS but as I said it isn't advisable and BT wouldn't give after-support.
but you have your opinion and that's fine 🙂
Message 12 of 21
It is not an opinion it is FACT. Desist from posting erroneous information.
Tags (1)
Message 13 of 21
Thanks for all the replies guys.
i won’t be using VOIP services. I just meant basic configuration.
So from what I’ve gathered I can buy a semi decent router and just login through ppoe.. my question is do I need BT auth for assistance for this is is it just plug and play
Message 14 of 21
When you say routing I’m assuming you mean nothing past the first hop? Ie just what I can change on my end not routing past this point.
Message 15 of 21
@Sickofvirgin
changing router is just plug and play  no need to inform BT
Message 16 of 21
Just ignore @TECHHERO1984  I've no idea what he means by that, I doubt he does either.
Message 17 of 21
BT FTTP With Digital Voice - Alternative to Smart Hub 2 :: Fibre Broadband :: think broadband
just because Liquorice is unfamiliar with something doesn't mean it can't be done, I am quite shocked that he is quite dismissive on here of new information and comes across quite rude.
I would ask that the moderators have a look at some of his messages moving forward
Message 18 of 21
I'm perfectly aware of that thread and have, in fact, referenced it on the forum in the past.
You clearly haven't read that thread fully. If you had, you would have seen that the Smart Hub2 was still required to provide Digital Voice albeit not as the first connected device.
The methodology employed to do so is far beyond the scope of the vast majority of customers.
Message 19 of 21
This is what I said in my original post, that it "isn't recommended", its you who's giving out false information that it's not possible when others have done it.
and you are quite a rude and dismissive in your posts they are borderline troll like , this forum is here to offer different opinions and ideas and respect should be shown at all times.
telling people to ignore people and sending insulting text in posts is not a great thing and I will ask that the moderators take a closer look at this
Message 20 of 21
I don’t know why your arguing over something that wasn’t part of the post, not even sure why the voice was brought into the conversation.
also I think liquorice was referring to your comments regarding routing, not the voice.
