Anonymous
Not applicable
Message 1 of 4
Openreach fibre database error?
Hi
The flats complex i live in has 74 flats spread over 4 blocks. The Openreach checker says fibre is only available in flats 1-54 and is not available in flats 55-74. Luckily am in the 1-54 and have ordered fibre. To help my neighbours can someone check if it is a database error for flats 55-74.
3 REPLIES 3
Message 2 of 4
Re: Openreach fibre database error?
Hi, @Anonymous Your neighbours could fill in this form to ask Openreach if it's a database issue. Fibre availability enquiry | Openreach
Neil
Message 3 of 4
@Anonymous
The only people who can answer that question are Openreach.
However, as you say it's 4 blocks of flats that suggests 4 separate buildings so it's quite possible for not all 4 to have yet been cabled for fibre.
Anonymous
Not applicable
Message 4 of 4
Its 4 blocks but in 2 pairs joined together so it would be strange only to do one half of a pair.
