Message 11 of 17
Re: Orange light, line is in synch and live, both BT and third party modems do not work!
Message 12 of 17
@NickX
On the WAN connection screen what options do you have for Service Unit?
The manual isn't overly helpful here & is probably out of date.
Can you also screenshot the DSL Settings under the Administration tab please.
It should look something like this :-
Message 13 of 17
The Service unit looks like different profiles it has from 1-8 and it changes the option of PPPoE to Bridge but i have the option to change it back.
Message 14 of 17
I'm suspecting the fault isn't with your hub or the Asus. Sounds more like a circuit build problem.
Message 15 of 17
@NickX  I'll flag it to the mods to see if there is anything they can check.
Message 16 of 17
Hi @NickX and welcome to our community.
Thanks for posting. I'm sorry you're having problems getting this sorted. It looks like you've done as much as you can from your side so I'll be happy to take a look at this for you. I'll need a few detail so I'll drop you a private message now so you can get in touch.
Thanks @licquorice for raising.
Cheers
David
Message 17 of 17
Thanks for taking my call today @NickX . I'm glad everything is up and running for you.
Cheers
David
